dseelig Posted June 8, 2007 Share #1 Β Posted June 8, 2007 Advertisement (gone after registration) Well I gotrmy 21 zeiss recognized as a 21 summicron. One difference between the 25 zeiss I coded as a 24 elmarit. I needed to get teh screw area white. The 28 summicron is the same but one more black where the4 screw lands on the zeiss. MY 21 kept reading asa a 28 I took a piece of tpae over the screw area and presto it reads as a 21. I did not wan to paint the screw in case the lens ever needed work. Masking tape worked but I ended up using a piece of tape from a label for a slide I never used. I cut the tape to just fit over the screw. Link to post Share on other sites More sharing options...
Advertisement Posted June 8, 2007 Posted June 8, 2007 Hi dseelig, Take a look here 21 Zeiss 6 bit coding. I'm sure you'll find what you were looking for!
