Billingham S4
lpeeples
This is just a FYI post for any Billingham lovers.  I like Billingham a lot. I have a Hadley Pro, and love it. However, its tight when carrying my M and M246 and lenses (normally, a lens on each body and 2 additional).  I picked up the F1.4 and it was better. However, I had trouble getting 2 lenses side by side in the middle with each lens in a foam case. It was also difficult to put the camera body in the F1.4 with a larger lens like the Nocti with the other gear.  I the saw the S4 and picked that up. I had to order it direct from Billingham direct since it I couldn't find it the US.  Turns out, its a fantastic bag for 2 bodies with lenses and 2-3 other lenses.  As you can see in the photo, its wider at the bottom so I can fit everything I need to in the bag and its not much bigger that the F1.4.
I ended up selling the 1.4....
