SF 26 problem
Either I am the dumbest person in the world or the sf 26 is very confusing. I can't get it to turn on. I sent it to Leica repair and 79 days later it comes back. They said there was no problem.
So it must be me.
I press button 1 in the image - mount it on the hotshoe and release button 1. Then I press button 2. I think the flash should turn on. I do this before and after I turn the Q on - no difference. I press 2 again, holding it for 10 seconds - nothing. I press ttl and set the Q for flash always on. I take several shots.
However, the flash never comes on. Can someone tell me what I am doing wrong?
I thought button 2 was strictly a mechanical control of a pin the locks or releases it from the hot shoe. Am I mistaken?
Agree on the batteries. Get a tester and ensure the batteries are good. Then make double sure they are put in correctly. Very easy to get wrong and zero feedback when you do.
Good luck.
Agree regarding the batteries. I experienced the same challange.
I am also of the opinion the flash is quite ordinary. A few weeks back I went to the Leica Store, and discovered that there are many others who share my opinion including those who worked at the store. The flash does not do a very good job of covering an area, has dark and lights spots, the TTL is mediocre, and overall it is not up to Leica standards (at least according to what myself and other believe). Candidly, I would not recommend it.
