Level Gauge
Lucena
Hi everyone, from Dubai.
I dont know why the level gauge do not show anymore, I Went on the menu, it was on. I put it off, restarted the Q, then on again and still does not show. Just have the grids.
anyone has any clue?
Thanks.
x
I have it set for on all the time and don't find it distracting. But tilt the Q and with a 28mm lens those converging verticals will look awful.
I haven't tried to figure it out, but is it possible to not lose the level once the shutter is half-pressed?  I find that kind of annoying, but obviously not annoying enough to try and fix it! :)
I also was wondering if the level works when looking straight up or down ... or does this traditionally not work, even for other cameras too?
It does indeed work if you point the camera directly down to the floor.
While I do see the level gauge when pointed straight up (or down), I cannot obtain 'green lock' (i.e., green lines (both long and/or short)) in any reasonable sense with the camera in this orientation.  Can you or are others actually able to obtain 'green level' status while aiming straight up or down?  Just trying to figure out if it's my camera, or if I've misunderstood something here ...
Many thanks!
