Hotblack Desiato Posted February 1, 2016 Share #1 Posted February 1, 2016 (edited) Advertisement (gone after registration) Hello I have this marvellous lens and a Digilux 3 (and a Oly E-300). The only "flaw" of the camera: it somehow fuses with the hands and it takes a lot to put it back into the camera bag ;-) However, the lens has a more severe flaw, it allows zooming just from 14mm to approximately 21mm. Then there is something blocking the zoom ring. I already disassembled the lens (remove the 2cm wide rubber ring, unscrew the 5 screws, then try to fix the screws underneath it). Sadly, it didn't work. Any ideas how to get the lens up and running again? It's still working perfectly as a near-prime (14-21mm isn't a lot). Did I miss anything? And what is Leica telling about that flaw (found numerous reports about that flaw). I still have the oly 14-50mm (3.5-5.6) and 40-150mm (3.5-4.5) (the old ones), which work quite well on the leica Digilux 3 as well, yet it would be really nice to have the leica camera and lens working together as intended. Any ideas? (I know, I could post in the german part of the forum aswell, I'm from austria), but I expect more help in the english part of the board) Edited February 2, 2016 by pop Fixed the model name Link to post Share on other sites More sharing options...
Advertisement Posted February 1, 2016 Posted February 1, 2016 Hi Hotblack Desiato, Take a look here Leica D Vario Elmarit 1:2,8 to 1:3,5; 14-50mm stuck (Kit-Lens Digilux 3). I'm sure you'll find what you were looking for!
pop Posted February 1, 2016 Share #2 Posted February 1, 2016 Would the camera not be the Digilux 3? There used to be a D-Lux 3, but it had a fixed lens. Link to post Share on other sites More sharing options...
Hotblack Desiato Posted February 1, 2016 Author Share #3 Posted February 1, 2016 (edited) Sorry, my bad. I thought that D-Lux is the abbreviation of Digilux. It is the Digilux 3 (equal to Panasonic L-1). apparently there is no way to edit the initial posting. Edited February 1, 2016 by Hotblack Desiato Link to post Share on other sites More sharing options...
pop Posted February 2, 2016 Share #4 Posted February 2, 2016 I have fixed the name. Link to post Share on other sites More sharing options...
Hotblack Desiato Posted February 2, 2016 Author Share #5 Posted February 2, 2016 Thank you Do you have any clue about the lens? Apparently, that particular problem is quite common with this lens, and usually it's fixable by tightening those three inner screws (I should have made pictures during disassembly). Are there other screws aswell? Link to post Share on other sites More sharing options...
dkCambridgeshire Posted February 3, 2016 Share #6 Posted February 3, 2016 http://www.dvinfo.net/forum/panasonic-lumix-g-gf-gh-gx-series/513959-has-anyone-had-problems-lens-panny-14-50mm.html dunk Link to post Share on other sites More sharing options...
Hotblack Desiato Posted February 3, 2016 Author Share #7 Posted February 3, 2016 Advertisement (gone after registration) 5. you can see three more screws on the inner barrel of the lens. In my case, all these screws were loose And here is the problem. These 3 screws were wonderfully tight. I was able to loosen them a bit and retighten them, the only result was, that I lost another 2-3mm focal length (It doesn't really matter, if I can zoom from 14 to 23 or to 21mm). I've read other postings where people described that dismantling it to this point and tighten the screws did not help, so my guess is, that there is something else blocking the zoom ring. Oh, and I did not use the glue. I think, that this stuff should not be anywhere near a lens. Link to post Share on other sites More sharing options...
capturedby.lumo Posted December 24, 2023 Share #8 Posted December 24, 2023 Hello, you are not alone, I habe the same problem with the exact same lens and camera and it is stuck at the exact same focal length. Have you found a solution yet? Link to post Share on other sites More sharing options...
