Leica S 120mm for Landscape Photography
LeicaR10
Sailronin,
Thanks for posting your excellent images of Death Vally NP.  The images show the detail that can be had from the 120mm for landscape images.  I spend a lot of time in Death Valley myself.  The Mesquite Dunes are a great place at sunrise especially after a sand storm...erases the footprints.  From your images, it looks like the 120mm does a excellent job at infinity for resolution.  I appreciate your comments and help.  R/ Mark
I can't speak for the 100mm, as I don't have that lens (I wish ...) but I can wholehaertedly confirm that 120mm is a very capable landscape lens. I have 60 x 90cm prints that do look wonderfully sharp and rich in colour and contrast. The only thing to watch out for with the 120mm (as with any longer lens) is your shooting technique, generally a lot of light is needed to get good/safe shutter speeds and apertures.
On their website Leica writes "the perfect portrait lens" for the 120mm.   This may be true however it doesn't preclude it's use for other purposes, and I believe this was written prior to the release of the 100mm lens.   Leica makes available mtf curves at infinity and close up.  Most lenses are optimized for infinity, however macro lenses can be an exception such as the Zeiss 120mm for the Hasselblad V system, and they may be optimized for closer distances.  The 120mm Leica Macro has significantly greater contrast (for all intents this is resolution) at infinity than close up, making this lens perfect for landscape and for that matter portraits also.
When I did a quick test of the 100mm vs. 120mm, the 100mm had softer corners, the 120mm would be preferable for landscape.  If I was a portrait photographer I would use the 100mm.  For landscape primarily and portrait secondarily it is difficult to beat the 120mm.  Again Leica's mtf curves bear this out.
For landscape the use of the 120mm and 180mm lens give me similar qualitative results, both outstanding.
Peter V & Daryl   Thank you for the comments about the 120mm.   I went and did extensive testing of both the S 100mm and S 120mm lenses.  From what I and Leica dealer staff can see in our opinion, is the 120mm is very sharp, better contrast and resolution for the images.  The images all the way to the edges are amazingly sharp. The 100mm was very good, but we believe and think its better suited for portrait and fashion photography.  Again, our opinions and observations. We can say too, both draw differently as well.  Based on the day spent shooting, testing landscapes with both lenses I decided to buy the 120mm lens.  Now if the lens focus motor doesn't die, it will be exceptional...just a tongue in cheek comment.
To All who contributed comments and images to this topic, thank you.  I can say the S 120mm lens is superb for landscape photography.  Sharp edge to edge, excellent contrast, resolution and ability to draw a landscape image very well.  I am very please with the 120mm S and I feel you will too if you are thinking about purchasing the lens for this purpose.  Thanks again to all who commented and those that viewed this topic.
I think you need to ask which lens is better for stiching, it would seem that you will eventually stiching landscapes if you don't already and I would also inquire if the answer includes using a VR drive. That combination will change your landscape photography for ever!
Bab,  Thank you for the suggestion concerning stitching and VR.  I do both and I am expecting superb results from the S-120mm.   I just purchased the lens and have not had the opportunity to get to a scene yet to test the lens and stitching in that capacity.  I appreciate your suggestions.  So far the lens is superb for landscape photography.  R/ Mark
John,  I agree with you.  This and all the S lenses are excellent.  Being a "medium format" camera certainly has its pros and cons.  The size and weight being one of the cons.  Not so much the camera body IMO, but the lenses are heavy.  Yet, they deliver superbly.   I wonder if Leica ever considered making the S lenses without the auto focus like Zeiss lenses.   I wonder if there would be a market for S lenses for landscape photographers....Just a passing thought.  There are other applications where a photographer using an S camera doesn't want or need AF.  I suspect the lenses would cost less too.
Again, thank you for your comments.  R/ Mark
  • 4 months later...
Guest NEIL-D-WILLIAMS
120mm with 4 stitched frames
  • 2 weeks later...
The 120 Macro is a wonderful landscape lens, a couple of examples are below from Death Valley National Park about 3 weeks ago.
And finally a panorama of 2 120mm shots stitched together.
That is well done
