pico Posted December 26, 2015 Share #1 Posted December 26, 2015 Advertisement (gone after registration) Regarding in-camera maximum data transfer. The following measures were made from the hidden M9 service menu. I used a couple cards that were on the table. Does this show exactly where the bottle-necks is?16gb SanDiskWRITE: 1609ms, Rate 3182 kB/sREAD: 1443ms, Rate 3548 kB/s16gb Lexar 100xWRITE: 1697ms, Rate 3017 kB/sREAD: 1437ms, Rate 3562 kB/s Not fast! Link to post Share on other sites More sharing options...
Advertisement Posted December 26, 2015 Posted December 26, 2015 Hi pico, Take a look here SD card read/write from in-camera diagnostic. I'm sure you'll find what you were looking for!
hepcat Posted December 26, 2015 Share #2 Posted December 26, 2015 Pico, my ignorance is showing, but are there benchmarks to compare these figures with? How should I interpret this raw data? Link to post Share on other sites More sharing options...
CheshireCat Posted December 26, 2015 Share #3 Posted December 26, 2015 Does this show exactly where the bottle-necks is? I would say that the bottleneck is the M9 SD controller. BTW: How do you enter the hidden service menu ? Link to post Share on other sites More sharing options...
tobey bilek Posted December 30, 2015 Share #4 Posted December 30, 2015 I would say that the bottleneck is the M9 SD controller. BTW: How do you enter the hidden service menu ? I suggest the problem is in the electronics/processing in the camera. The cards works fine in other cameras, but are slow as a turtle in M8 & 9. I would advise against using high capacity cards,> 16, or fast cards in the M9. Stick to what is listed in the manual. Link to post Share on other sites More sharing options...
