krissheldon Posted May 30, 2007 Share #1 Â Posted May 30, 2007 Advertisement (gone after registration) Can I get some input on what lens code to use on my 135 mm APO-TELYT? Â Thanks, Â Kris Link to post Share on other sites More sharing options...
Advertisement Posted May 30, 2007 Posted May 30, 2007 Hi krissheldon, Take a look here Lens Coding for 135 mm APO-TELYT. I'm sure you'll find what you were looking for!
Guest guy_mancuso Posted May 30, 2007 Share #2 Â Posted May 30, 2007 You can code it for the leica 135mm 2.8 but it will only serve you for EXIF data Link to post Share on other sites More sharing options...
krissheldon Posted May 30, 2007 Author Share #3 Â Posted May 30, 2007 Actually, what I wanted to say is what coding should I use in relation to frame lines? Â Thanks, Â Kris Link to post Share on other sites More sharing options...
Guest guy_mancuso Posted May 30, 2007 Share #4 Â Posted May 30, 2007 Well on the M8 the frames lines do not come up for the 135mm. What i did was sent my 135 apo in and had leica remove the 135mm mount and replace it with a 90mm mount so when the lens goes on the 90mm frame lines would appear. this gives me a guide to use with the 35mm lens and actually framing is between the foucsing patch and the 90 frame lines. It helps with composition than with that i had it code for 135mm but that only effects the EXIF data not the framelines Link to post Share on other sites More sharing options...
