Who wants an Interchangeable Lens AF Q camera?
algrove
x
Interesting. Why not? (serious question).
Well, perhaps not just as described, but why is the Q compact but the SL isn't?
I'm sure there are compelling reasons that will shut us up, but it is a real shame.
We all know that an interchangeable-lens Q  system would be a real winner.
If only the impossible weren't so awkward.
Personally I hope Leica will bring out a Q with a different lens such as a 35mm on with 50mm and 75mm crops.
Most importantly I hope that Leica will bring out a weather sealed Q.
Actually, I am wondering if Leica will do what Fuji did for their X-100 series, by introducing tele-converter lens to covert 28mm to 35mm, 50mm, etc
No interchangeable lenses if that means getting as big as the SL..
It doesn't. Such solution would probably be a little larger than the Q, but not significantly larger. It is important to understand that the design goals for the two cameras, Q and SL, were simply very different. And I'm not at all surprised if I'm told that the SL project begun first. I actually assume it did.
As a customer, an SL Lite that is closer to Q would make a lot of sense. It is not realistic to expect seeing one anytime soon, though.
Agree
And they may name it SLK :-)
I would like a Q with a TRI-ELMAR, perhaps 35-50-75mm, or even just a "BI-ELMAR" 50-75mm as the 28mm Q is already covering the wide side. As an alternative, a fixed focal 50 or 75mm would be fine.
In fact your Tri-Elmar comment is a good one. I do not see any Q getting bloated like the SL.
