Fotograph Posted September 28, 2015 Share #1 Posted September 28, 2015 Advertisement (gone after registration) Keine M, keine Q - bleibt die Hoffnung, dass die M immer noch so schön "mechanisch" bleibt..... Was sagt ihr dazu?: This will not be the replacement to the M240 but rather a new system with new AF lenses, bulkier than the Q or M lines, with an EVF and lighter build despite the bulk. Sensor will be similar, if not the same, as the Q’s sensor. Anticipate that it will come bundled with a 50 mm f/2 Summicron lens and retail around $8,000 USD. Build quality will be comparable to the M line and Q line…much of the Q’s tech, including in body image stabilization, electronic shutter, and built in high res EVF, will be included. The camera may harken in design to Leicaflex bodies of years gone by…like a bulkier XT-1with more simplified layout. This may end up being called the new “R” camera and may well take old R lenses via adapter, along with new AF R lenses. Not sure that it will take M lenses. Link to post Share on other sites More sharing options...
Advertisement Posted September 28, 2015 Posted September 28, 2015 Hi Fotograph, Take a look here "M"ilka "Q"uh. I'm sure you'll find what you were looking for!
