Voightlander 12mm Hood issue
Guest guy_mancuso
Guest guy_mancuso
Well i go my CV 12mm and it is very nice and actually quite sharp , will run some test later but I think I screwed up my hood on it and it is really bumming me out becuase you have to have it becuase the elelment sticks out to far without it. I can't get it to tighten down there is a push screw in there and it is not working very good at all. Trying to come up with a better way to get this to stick on firmly. Anyone else have this issue or maybe a solution . I'm about a inch away from grabbing the super glue but i am resisting. Maybe I can just buy the hood?
x
Guest guy_mancuso
I think what happened to it was me , I think I pulled when i should have unscrewed. Sean looks like off seems the best until we get something custom made from John and add a little from a raw program that has the cyan drift in it to fix. But it is a little sweetie so far and i do like the focusing stops in it, would have been nice if the 15mm did that
Guest guy_mancuso
Okay I may try that Sergio and was thinking on those lines. i knew this had to happen to someone the build on it is good but not perfect on the hood, weird design. The lens build is very nice though
So far no issues with hood but I will certainly be ginger about tightening it down!.I am also ready for the cyan software beta trial though!
I've made a prototype and found that the 55 fliter glass works. It will be about a week or two before i can get the machine free to make a run. the adapter is to be black anodized aluminum, will have a threaded retaining ring for the 55 glass and will have an integrated shade. attachment to the lens will be similar to the C/V design.
Hi John,
Cool, I'm glad the 55 works. Have you tried it with the 486 filters as well as the Leica filters? The former have a deeper mount ring.
Cheers,
Sean
