m246 spectral sensitivity
jbl
With the original MM, Leica published a chart of the sensor’s spectral sensitivity. I can’t seem to find one for the M246 CMOSIS sensor. Has anyone seen one?
Anecdotal observations so far… Open shade with a yellow (#8) filter is around f/4, 1/250s, ISO 1000 (EV11) so at least at ISO 1000, the effective ISO is more like 250.
-jbl
  • 2 weeks later...
Here's what I'm guessing will be a more helpful view (I own a complete set of B+W filters, so I was able to test this), which is in daylight shot on 90% reflectance neutral media (trial 1 is diffuse sunlight; trial 2 is bright sunlight). The scale is in PS levels, from the DNG, center-of-frame. I set the exposure to 320 ISO, manual setting such that no filter clipped white. Not a perfect test, but close enough.
Understand that color contrast filters do not make hard cuts (as would be used in a spectrographic analysis), so things look a little different from a basic sensitivity chart. This infers the sensitivity.
The reason why your yellow 8 looks so powerful is that open shade has a lot of blue light in it. For neutral-colored objects, the yellow 8 is actually the most transparent filter available (except to blue light). A lot of shots with the M typ 246 and orange and red filters look muddy, and that is not a surprise.
This chart is mine; not for further reproduction.
Dante
This would obviously not be representative of colored objects, but it tells you what you have to do to get the neutral ones to the exposure you want.
I really want to do something like this with focus shift, which seems to be an issue with some lenses and filters.
D
  • 3 weeks later...
Interesting. I'm not sure if i interpret the chart right. What's the unit on the Y-axis? What's it representing?
Absolute level returned by Photoshop from the default-rendered RAW file (0-255), set so that the white target clipped as closely to 255 as possible. I have also changed these to log sub 255 charts here:
https://themachineplanet.wordpress.com/2015/09/16/the-leica-monochrom-typ-246-and-filters/
So that you can see how the shapes compare to other media.
Dante
