Q-protector problems
I bough the Q-protector for the Q, but the opening under the flap is to small so the battery compartment door won't open.
Be sure to check it before you buy it. Seems to be some quality control glitches at manufacturing now.
Bought mine from Meister camera online, but I am located in Sweden. So this is going to be a hassle to get replaced. Bummer....
Mine doesn't have the problem, although just like Bird said: I need to open the flap to way more than 90 degrees for the camera battery door to swing open. Otherwise it hits the flap
where or how does your battery door get stuck?
The battery door opens about 1mm. Not more. I figured out that the opening is misaligned. Meister Camera has offered me a replacement one.
