Led, one is missing
Annibale G.
It's about a fortnight ago that I noticed something strange on my M7. Apart the lower dot blinking without using exposure compensation , a part of the LED is missing: for example if I use a iso of 400, the camera dispay 400 , but the upper line of the zero it is not displayed. Do I have to worry about that? What I have to do?
Thanks
Annibale
x
In case your camera is still under warranty you can send it in and have it repaired at the CS.
If not - and you can work with it, and the camera works alright otherwise - have it repaired once your camera has to be send in anyway for a check up.
I try to have mine serviced every ten years or so, to avoid runnning on empty ...
Best
You seem to have two problems with your M7: blinking dot AND missing elements of the LED-display.
The incomplete display would be a thing I could live with, but the dot is a nuisance which I would like to see altered ...
Give the Customer Service in Solms a chance to do something about it, as long as there is a warranty on the camera.
Best
