mltx Posted April 20, 2015 Share #1 Posted April 20, 2015 Advertisement (gone after registration) On M 240, the maximum pixel size for DNG is 5976x3992, whereas the one for JPG is 5952x3968. I wonder why they are different? (And on M-E they are identical.) Link to post Share on other sites More sharing options...
Advertisement Posted April 20, 2015 Posted April 20, 2015 Hi mltx, Take a look here Why pixel sizes between DNG and JPG different. I'm sure you'll find what you were looking for!
asfeir Posted April 20, 2015 Share #2 Posted April 20, 2015 The answer may be the following: DNG pictures are a mosaic of Greens, Reds and Blues (Bayer pattern). Once demosaicing takes place every pixel will have three values of R, G and B respectively. These values are obtained from interpolation of the Bayer pattern. It may be that the outer rows are eliminated by these interpolations because the interpolation algorithm applied at any point, needs more than just the 4 RAW pixels around that point. Link to post Share on other sites More sharing options...
CheshireCat Posted April 21, 2015 Share #3 Posted April 21, 2015 There are usually two reasons: 1) The desired aspect ratio is 3:2. 2) Demosaicing algorithms don't need to take care of special cases at the borders and corners. Link to post Share on other sites More sharing options...
01af Posted April 21, 2015 Share #4 Posted April 21, 2015 A JPEG picture can have any size but the JPEG compression algorithm works best (most efficiently) when the pixel count along the frame's short and long edge both are multiples of 16. If at the same time the frame's aspect ratio is supposed to be 3:2 exactly then the short edge must be a multiple of 32 (2 × 16) and the long side a multiple of 48 (3 × 16). To provide enough interpolation data, the raw image should be a couple of pixels more. It is not impossible to convert a raw image to a JPEG image with exactly the same pixel count—but that would require additional computing power and may lead to strange artifacts at the edges. Link to post Share on other sites More sharing options...
mltx Posted April 22, 2015 Author Share #5 Posted April 22, 2015 Thank you very much for all of your very knowledgeable enlightenment. While I learned quite a lot from those answers, I am still puzzled when comparing M240 with M-E: M-E resolution: DNG=JPG: 5212x3472 (according to tech data from Leica) DNG: 5212x3468 (according to actual file attribute) JPG: 5216x3472 (according to actual file attribute) So here for M-E, if you look at the actual file attributes on a computer with any app, you can see that JPG has more pixels than DNG?! And the JPG's ratio for M-E is not exactly 3:2 either. Maybe that is because of the sensors' difference between CMOS and CCD? Link to post Share on other sites More sharing options...
CheshireCat Posted April 22, 2015 Share #6 Posted April 22, 2015 JPEG files with 4:2:0 chroma subsampling must have width and height that are multiple of 16 pixels. This is a requirement of the compression algorithm. But JPEG files also embed crop parameters for width and height, so the actual picture dimensions is not limited to multiples of 16 pixels. I don't have any M9/MM/ME JPEG files at hand to check, but I guess you are seeing the data dimensions, not the actual picture ones. P.S. The actual sensor specs are even more interesting: http://www.onsemi.com/pub_link/Collateral/KAF-18500-D.PDF Have fun ! Link to post Share on other sites More sharing options...
mltx Posted April 24, 2015 Author Share #7 Posted April 24, 2015 Advertisement (gone after registration) JPEG files with 4:2:0 chroma subsampling must have width and height that are multiple of 16 pixels. This is a requirement of the compression algorithm. But JPEG files also embed crop parameters for width and height, so the actual picture dimensions is not limited to multiples of 16 pixels. I don't have any M9/MM/ME JPEG files at hand to check, but I guess you are seeing the data dimensions, not the actual picture ones. P.S. The actual sensor specs are even more interesting: http://www.onsemi.com/pub_link/Collateral/KAF-18500-D.PDF Have fun ! Thanks for all the information. Link to post Share on other sites More sharing options...
