M6 TTL Light Meter Issues
Hi there,
I have an M6 TTL that I've now had repaired twice and am still not convinced is working as should be. The exposure meter seems out by two to three stops I think.
The symptoms that make me think this are:
- if I compare it to a sekonic light meter reading (even accounting for reflected light) it seems way out.
- comparing the metering against an analogue and a digital camera it seems out
- and when I put the TTL flash on it it seems to think it's on ISO 64 rather than 400.
My questions are - do you think given the above something is wrong? And, is there a better way to test and verify what's up for myself?
Many thanks,
Fraser
I have a M6TTL myself with some of the same issues. I have not tried with flash, but without it was 2 stops off. I opened up the ISO dial and put it together again. It now seems to be OK, wich mean that my assumption that ISO dial was missplaced previusly might be correct.
