sean_reid Posted May 16, 2007 Share #21 Â Posted May 16, 2007 Advertisement (gone after registration) Sean,Did you test the 21/4 against the wate code as well and decided the elmarit correction was better? - C Â Hi Carl, Â Not yet. The WATE code in the "on" position applies a general correction regardless of actual focal length set on the lens (hence no EXIF listing of focal length either with this system). I would bet that its optimized for 18 mm. The "On + UV/IR" setting might work well for the CV 21 with filter. It's on my list of things to test. Â Cheers, Â Sean Link to post Share on other sites More sharing options...
Advertisement Posted May 16, 2007 Posted May 16, 2007 Hi sean_reid, Take a look here best code for cv21/f4 color skopar. I'm sure you'll find what you were looking for!
bradreiman Posted May 16, 2007 Author Share #22 Â Posted May 16, 2007 sean and carl- i used the wate code because i already have an adapter coded for cv 15. not a great code for this lens. next time i'll try the one sean recommended. all the shots were useable with a liitle cropping of the edges. im really loving having the filters now as it allows me to do color work with much less apprehension..b Link to post Share on other sites More sharing options...
Eikonphoto Posted May 16, 2007 Share #23  Posted May 16, 2007 Karen, is the metal of the lens mount clean and shiny? Older mounts may show black instead of white, unless cleaned. Also, is there a screwhole in the way? I had to fill one hole on my 75 Lux with whiteout to be able to code it. It is also crucial to use a pen with non-reflective ink. Is yours a Sharpie or an Edding 8400? If not, try one of those two. Check and re-check the locations of your marks. A slight error can make a big difference.  Carsten I made sure the lens mount was clean, and there is no screw in the way. I just dropped my 35 summicron, and now it's very stiff at the close focus. I don't know if there is a way to adjust it back to it's smooth focus, or whether I need to send it to be fixed. I'm more than a bit fed up, a glass of wine is the only answer. Link to post Share on other sites More sharing options...
carstenw Posted May 16, 2007 Share #24 Â Posted May 16, 2007 An alternative answer would be a bottle, and the 90 Macro Link to post Share on other sites More sharing options...
