auto iso is not working
when the 240 first came out, i had a similar problem. with the first update in firmware, the problem went away. now, it is here again: when i set the max iso to 1600 and the shutter speed to 1/f, the iso stays at 200 and the shutter speed falls below 1/f. is anyone else having this problem?
thank you for the link. i discovered the solution on my own, but it worked just as the link suggested. after i made the post, i realized that the camera was not reading the lens correctly - the frames were for a 50 mm lens, not a 28 mm lens. so i unscrewed the lens and screwed it in again. thereafter the lens had the correct lines and the auto iso worked. go figure.
