What focal lengths is the 6 bit coding really need for?
paulau
Hi,
I am wondering which of my lens to get modified for 6 bit or buy a custom screw to M to adapter for. Is it only necessary for lenses wider than 28mm? should i actually bother with say a 50mm?
Any thoughts would be appreciated.
Regards,
Paul
Hi,
Regards,
Paul
Hey there Paulau; Welcome to the forum. From what I have read and my personal experience, coding of lenses is not necessary with lenses longer than 35mm (under 35mm length, yes, I would code the lens). So your 50mm, 75mm, and 90mm lenses really don't need to be coded. In fact, according to the latest Sean Reid article on 75mm lenses, coding the 75mm lens actually results in an over-aggressive correction of vignetting- you are better of NOT coding the lens.
Hi Lloyd,
Right...that's true with the current firmware at least. Newer firmware may be better dialed in for that correction. In any case, the coding is needed for 35 mm and wider lenses when the IR-cut filters are used. I say that based upon my own fairly extensive testing.
Cheers,
Sean
Ok, thats good, less lenses to do :)
Is it worth using an IR cut filter on a 50mm? also if i'm not using the filter on a lens wider than 35mm, should i still code it?
Regards,
Paul
Guest guy_mancuso
The IR filter is used to cut the IR contamination so yes every lens you have. Coding serves two puposes one for vignetting and the other to eliminate the cyan cast created by the IR filter for lenses wider than 35mm. Actually there is a third coding also will give you the lens used in the EXIF data
HI Paul
I'm doing all of mine - it's just great to have the lens information in the exif. I do mostly nature and landscape photography, and I've decided (for now at least) that I get better results without the IR cut filters - but I still like to have the lens information.
You pays your money
