Tim B Posted May 14, 2007 Share #1 Â Posted May 14, 2007 Advertisement (gone after registration) I too have experienced the weird AWB on my M8. However, I have also discovered something strange when using manual Kelvin settings. Â I experimented this evening using my new 28mm Elmarit-M f/2.8 ASPH. Using a B+W 486 IR cut filter, shooting with Tungsten lighting, I set 3000K for white balance, which looked pretty good on the LCD. However, on opening the file in ACR 3.6 the white balance setting shows up as 3300K. The same shift occurs at other settings too. Â Has anyone else noticed this? Any explanation? It is a bit of a nuisance since I then have to reset WB in ACR. Â Tim Link to post Share on other sites More sharing options...
Advertisement Posted May 14, 2007 Posted May 14, 2007 Hi Tim B, Take a look here Manual WB weirdness. I'm sure you'll find what you were looking for!
