Just wanted to note that the small dark gray battery lock/latch has broken on my X Vario. It is made of plastic and it has split, leaving a portion of the mechanism in the body. For reference it happened while trying to take the battery out to charge it and not when putting it in. It doesn't look like it's user replaceable, but I am moments away from leaving on a trip so I will have to look into this when I get back. Has anyone managed to repair this on their own?
Fortunately, the camera is still operational without the clip, the battery/sd card door itself holds the battery with enough pressure to make the contacts.
I see it happened on someone's X1, but I figured I'd start a thread for this issue on the XV.
Sorry to hear this. I had a similar issue with my X1, and there is/was a thread on this as well, about 6 months ago.
Mine (X1) was repaired by the local Leica facility, quickly, and efficiently.
If you are past a Leica repair facility on your travels, maybe ask, it is a simple and reasonably straightforward repair.
While I agree, on this level of equipment it should not happen, it did, but was rectified painlessly.
Gary
  • 4 weeks later...
I just wanted to follow-up quickly on this issue and report that it's been resolved. I contacted Leica in New Jersey by email and they sent the part free of charge to Canada.
No instructions were provided and I did find it was a bit tricky to put the part in. Before I could install the new part, the bottom half of the clip was still in the camera. I can't really say that I removed it the best way possible... I forced the part sideways in order to allow it to slide out. The only other way I could think of doing this was cutting the broken part in two. The inside of the X Vario is plastic so I don't really recommend removing the broken pieces like I did, I could have easily damaged the housing of the battery lock.
After extracting the broken half from the camera, I put the spring onto the new clip and tried to install it many times before succeeding. The spring tends to fall inside the camera body but I almost lost it outside the body a few times. Make sure you do this in a well lit area, I found it was easiest to lay on the ground and do the work there. I had very thin tweezers that allowed me to pressure fit the spring onto the battery lock and using two pairs of tweezers I managed to hold the battery lock in place and use a second pair to press the new clip into position.
I realize that there was perhaps a way to simplify this repair by removing the bottom plate, but I was not sure what that entailed so I chose to do it from the outside. I have to say that you are really proceeding at your own risk when repairing the battery lock!
  • 5 months later...
I had the problem of broken latch one year ago; thought about "bad luck". Last May, when visiting New York city brought the camera to a workshop and it was repaired satisfactorily. Those days visiting B&H I bought an almost new LX1 at a very attractive price and felt very happy to have an excellent camera with an excellent back up.
BUT.... everything went well up to a couple of days ago when the latch of the second LX1 also broke. Just now, I realize that the first breakage was not matter of bad luck. It is matter of simply, ordinary bad design. Pitty, I had plans to go up in the Leica X line. I will not, of course.
Eduardo
Eduardo
How sad, there are probably 100's of thousands Leicas that do not have a broken battery catch. I suppose if you have a light bulb on your vehicle you cannot replace yourself you adopt the stamp my foot" attitude!
Things break, that's why there are repair specialist!! Everything could possibly be designed better but the cost might inhibit even you buying the product. Get it repaired, chill out, enjoy...
Considering the use this battery latch experiences, I do believe more attention could have been given to making the design and material more durable
I agree, but it is how it is. My X1 & XVario get regular use, I just take a little more care when replacing batteries. If the catch breaks Leica will be there for me. I agree the turn around times are frustrating, so my 2 DSLR Nikons, Safari & V-Lux's will get a well deserved
work out..'(^_^)'
  • 3 years later...
Hi,
I have the same issue with my XV. The camera operates w/o the battery tab. Is it safe to keep the camera this way? Is it possible to cause any other issues since it is missing the battery tab? As of now I made a couple layer of gadgets tape to try and keep the battery as right fit as possible.
Thank you and warm regards,
Justin
  • 1 month later...
On 1/19/2019 at 10:44 AM, JustinY3 said:
Hi,
Justin
Justin, the battery lock on my XV also broke. I used a thin bit of folded paper to keep it snug with the cover closed and had no problems using it that way for a few months. Eventually I had it repaired at Leica Wetzlar free of cost as a gesture of goodwill.
  • 3 months later...
2 hours ago, pmagee said:
Interesting. My replacement lock eventually broke again. I never bothered replacing it again and just keep the battery loose in there. So far it hasn't been an issue!
+1
Hi, all - I received the replacement lock from Leica USA in about a week, and just installed it.  After searching the toolbox, I found a pair of jewelry-sized bent-nose needle nose pliers to insert the new lock quickly and safely.
Cheers, Mike
