Delders Posted May 11, 2007 Share #1 Posted May 11, 2007 Advertisement (gone after registration) Question: I wonder if anyone can help me with a problem I have with a recently purchased mint Leitz 253 IR projector. When it arrived via courier I naturally tested it and regrettably discovered a problem which the vendor assures me he had never experienced. The problem is that when switched-on the projector will sporadically attempt to change slide (and occasionally actually change) whether there is slide in the gate or not. Having removed the covers it is clear to see the slide change solenoid fire without any user-input. Furthermore the direction of the change is backwards. All other functions work as expected forward/reverse using both the IR remote and buttons on the body; auto focus; bulb turret; Any help will be greatly appreciated. Link to post Share on other sites More sharing options...
Advertisement Posted May 11, 2007 Posted May 11, 2007 Hi Delders, Take a look here 253 IR Slide Changing Problem . I'm sure you'll find what you were looking for!
dkCambridgeshire Posted May 12, 2007 Share #2 Posted May 12, 2007 IR interference from another source?? e.g TV or radio remote control? Dunk Link to post Share on other sites More sharing options...
