Leica x2 lens hood
Paul Pilmer
  • 1 month later...
I use this hood (probably a KIWI, but it doesn't say). By the way, the hood accepts a 58mm lens cap.
fwiw, one can also use a 49mm pinch cap on these hoods which keeps dirt/dust off the lens (can get through the vents otherwise.)
p.s., the Kiwi tube/filter/hood/cap set up does make the camera larger but also can help keep dust from entering the camera and onto the sensor through the retracting lens which tends to suck in air (and the X2 isn't weather sealed.)
  • 5 weeks later...
I hadn't thought of that, but it gave me an idea. I have never used a UV filter to protect the front lens element, but I have now installed a protective filter between the tube and the lens shade to help prevent dust from being sucked onto the sensor. As long as it doesn't cause vignetting or otherwise obviously degrade the images, I will leave it.
Thanks!
Thanks!
A protective filter won't cause any vignetting, and I usually use one during the rainy season. The Hoya HD2 filters are pricey but tough, and the multi-coating works well. I usually take it off when the sun's out.
  • 2 months later...
  • 2 months later...
Must the Kiwi hood / tube be used to accommodate a filter on the X2? Seems it would substantially increase the depth and thus size of the camera.
