ironringer Posted October 26, 2014 Share #1 Posted October 26, 2014 Advertisement (gone after registration) Could experienced "adjusters" tell me how to adjust the IIIg rangefinder for correct focus when the lens is set at infinity distance? I was told that removing the front cover screw beside the rangefinder window reveals an adjusting screw needing a 1.2mm flat blade. Then, I believe, the process is to set the lens at infinity distance, look through the rangefinder at an object a mile away, and adjust the screw to merge the rangefinder images. Please confirm IF that is the procedure, or otherwise correct me. Is that adjusting screw tight, or relatively easy to turn? Link to post Share on other sites More sharing options...
Advertisement Posted October 26, 2014 Posted October 26, 2014 Hi ironringer, Take a look here How to adjust infinity on IIIg rangefinder?. I'm sure you'll find what you were looking for!
payasam Posted October 26, 2014 Share #2 Posted October 26, 2014 I have never even held a IIIg, but the procedure you describe is the same as that used with the IIIc and earlier Leicas. The screw is relatively easy to turn although it would not hold its setting if it was loose. Link to post Share on other sites More sharing options...
120 Posted October 27, 2014 Share #3 Posted October 27, 2014 Ironringer, let us know how it goes... Link to post Share on other sites More sharing options...
spydrxx Posted October 29, 2014 Share #4 Posted October 29, 2014 Never used a IIIG, but have several other screwmount variants. In addition to what you mentioned, I was advised also to remove the rangefinder cover ring on the shutter speed selector on the front side of the body, as it apparently contains either a prism lens (some models) or affects an internal vertical mirror adjustment (other models). It is the dual interaction of the vertical and horizontal adjustments which achieves perfect infinity focus. Typically the adjustment is made with a small caliper rotating the window. I check my gear seasonally about twice a year, as I've found that the adjustments are very sensitive to any impact (such as flopping against my body while hiking, or even geting jarred in the car on rough roads. It isn't rocket science, but the end result makes fine focusing much easier. Link to post Share on other sites More sharing options...
