sisoje Posted May 8, 2007 Share #1 Posted May 8, 2007 Advertisement (gone after registration) Well, this lens is DONE. Received the mount ring from Mr. J.M. today (great machining job!!!), did a little bit of "painting" and than replaced the mount on the lens. Now this lens has Leica UV/IR filter on and the proper frame lines (24mm instead original 28mm) when mounted (the original ring was replaced with 35/24 ring from Zeiss). The ring has a machined/painted code of Leica 24mm lens. It is differet from the specs on this list Leica M8 Lens Codes simply because the 35mm mounting ring requires focal lenght of 35/24 - not 28mm lens in order to "see" coding. I tried 28mm lens coding but in order for camera to implement this action, frame selector has to be manualy pushed to 28 frame lines. I did not like this, so decided to go with 24mm Leica code setting. Test ing to follow tomorrow.... P.S. the "problematic" screw was not a problem after all. A bit of white paint over it solved the problem.... Link to post Share on other sites More sharing options...
Advertisement Posted May 8, 2007 Posted May 8, 2007 Hi sisoje, Take a look here Zeiss 25mm/2.8:DONE. I'm sure you'll find what you were looking for!
