leica bottom replacement - missing magnet
barko
hi guy.. in need of desperate help--
i dropped the bottom cover after changing the battery. it seems that the magnet that was attached to the bottom cover has gone missing and now i can't operate the camera - i get an error that the bottom cover is removed although it is attached.
i looked online but cant find a replacement.
maybe you can help me find one - its size is 0.45mm.
i dont want to buy another cover..
thanks in advance
ofir.
Could the magnet be removed from the baseplate and glued instead over the "cover off sensor" area, so dropping the baseplate wouldn't cause the magnet to get lost? I really don't need being warned that the cover is off, I can kinda tell by looking ;) Or at least proactively remove the magnet and re-glue it with epoxy or some stronger adhesive.
Yes, there's even a recess in which to glue the magnet :D.
Bob.
