algrove Posted May 27, 2014 Share #1 Posted May 27, 2014 Advertisement (gone after registration) I am traveling with my Apple Air and have over 400 images on an external drive and in LR as DNG. I must provide these files to someone with a PC who cannot read DNG since he does not have LR or PS. So I must convert to jpeg preferably as a batch. Any suggestions on how best to achieve this task? Thanks. Link to post Share on other sites More sharing options...
Advertisement Posted May 27, 2014 Posted May 27, 2014 Hi algrove, Take a look here HELP-must convert DNG to jpeg on Apple. I'm sure you'll find what you were looking for!
dpattinson Posted May 27, 2014 Share #2 Posted May 27, 2014 If that is a Macbook Air, then you select all of the images in the Library view of Lightroom. Choose Export from the 'File' menu, and the export popup will appear File Settings: Select jpeg as the file type. Select sRGB for the colour space unless you know you need a different one. 90% quality should be fine. Image Sizing: You can choose to resize - for general web preview use I use 30cm on the long side and 150dpi. Otherwise just leave this for full-size jpegs. You get to choose where the jpeg files will be saved later on, so just hit the blue export button and off you go Link to post Share on other sites More sharing options...
