mehmet arcasoy Posted April 26, 2007 Share #1 Posted April 26, 2007 Advertisement (gone after registration) Dear Friends, I have seen a new lens from Voigtlander.It's 21 mm f:4 Pancake M mount.It's like old Super Angulon 21 mm f:4 but slightly small... Has anyone tried this lens ? I have Elmarit M Pre-Asph but bad condition and want to buy a new 21 but Leica is more expensive so I need your comments. Mehmet Link to post Share on other sites More sharing options...
Advertisement Posted April 26, 2007 Posted April 26, 2007 Hi mehmet arcasoy, Take a look here CV 21 mm f:4 Pancake M mount lens. . I'm sure you'll find what you were looking for!
stunsworth Posted April 26, 2007 Share #2 Posted April 26, 2007 Hi Mehmet, I believe it's the same optically as the existing Voigtlander 21mm but in M mount and a new barrel. If that's the case it's exceptional value of money. I have the original screw mount version and have been very impressed with it. Link to post Share on other sites More sharing options...
mehmet arcasoy Posted April 26, 2007 Author Share #3 Posted April 26, 2007 Hi Steve,Thanks for the info. I have seen this lens on the cosina.jp web site and advantage is directly M mount (Without any adapter ring) and comfortable metering knob and diaphram ring. I think the optical formula exactly same by the previous CV 21 Color skopar f:4 and Super Angulon M f:4. But I have some question marks about the vignette.Because there was a strong vignette on the Super Angulon M at f:4 and CV 21 Color skopar f:4. Link to post Share on other sites More sharing options...
wizard Posted April 26, 2007 Share #4 Posted April 26, 2007 But I have some question marks about the vignette.Because there was a strong vignette on the Super Angulon M at f:4 and CV 21 Color skopar f:4. Yes, that seems to be a weak point of all CV lenses I have tried so far (15mm, 21mm and 25mm), they do indeed produce noticeable vignetting even when stopped down to, say, f8 (I use these lenses mainly with color slide film, where vignetting is more easily visible than with prints). To counteract the vignetting of the CV lenses, I tend to expose my shots taken with these lenses 1/2 f-stop more than I would do with my Leica lenses (that is, if I would use f8 with the Leica lens, I use f5.6-8 with the CV lens). The results thus achieved are very acceptable to me. Otherwise the CV lenses provide excellent value for money, and they are so compact. Cheers, Andy Link to post Share on other sites More sharing options...
mehmet arcasoy Posted April 26, 2007 Author Share #5 Posted April 26, 2007 Did you compare by the Leica 21 mm Elmarit -M ASPH ? If it is nearly same quality may be it can be OK for the general use. Link to post Share on other sites More sharing options...
wizard Posted April 27, 2007 Share #6 Posted April 27, 2007 Did you compare by the Leica 21 mm Elmarit -M ASPH ? No, I do not own a Leica 21mm lens (I use this focal length not often enough to warrant buying a Leica 21mm asph.), but my general experience with other Leica lenses (I do own the 24mm asph. for example) tells me that Leica lenses vignette considerably less than their CV counterparts. Link to post Share on other sites More sharing options...
sdai Posted April 27, 2007 Share #7 Posted April 27, 2007 Advertisement (gone after registration) The M39 and the new M bayonet versions appear to be identical if you just look at the construction diagrams but Cosina should have upgraded the coating at least ... how much a difference there will be still remains to be seen and don't forget, folks ... there's the ZM 4.5/21 coming pretty soon and this one certainly looks very good on paper. Link to post Share on other sites More sharing options...
mehmet arcasoy Posted April 29, 2007 Author Share #8 Posted April 29, 2007 CV 21 M39 and M types are same optical construction.But I don't know the lens coatings etc...With B&W film CV is very sharp and contrastly,shadow detail is not very good but can be accept.I do not know on slides or color negatives. Leica lenses are certainly good...But, I know the ZM Zeiss-Ikon Lenses and Cosina makes these lenses too...Results of the ZM lenses same by Leica and sometimes more than good quality... The price of the CV 21 M is approx. 450 .-$ Leica is 3.192.-€ Once ,buy the CV is the best way I think....After some tests I will to make desicion to buy for Leica 21 mm. Link to post Share on other sites More sharing options...
zapp Posted May 2, 2007 Share #9 Posted May 2, 2007 The M39 and the new M bayonet versions appear to be identical if you just look at the construction diagrams but Cosina should have upgraded the coating at least ... how much a difference there will be still remains to be seen and don't forget, folks ... there's the ZM 4.5/21 coming pretty soon and this one certainly looks very good on paper. Anounced for quite some time Zeiss only lately put the performance pdf online - looking good. You can not order it right now, but probably soon. Link to post Share on other sites More sharing options...
meatboy Posted May 3, 2007 Share #10 Posted May 3, 2007 there's the ZM 4.5/21 coming pretty soon and this one certainly looks very good on paper. This is the one I am waiting for also, question is how much it will be? Tim Link to post Share on other sites More sharing options...
