ian moore Posted April 12, 2014 Share #1 Posted April 12, 2014 Advertisement (gone after registration) I recently took a series of photographs of a grey card to test the exposure setting of my Leica R9. I put the grey card in even light,zoomed in,out of focus,and took a series of exposures.First exposure was at the camera's recommended settings (designed to give a midtone),then I underexposed by -1 EV,then -2 EV,then -3 EV,then +1 EV,etc. I had the negative film developed and the series of tones seemed correct. At -3.5 EV the negative had very slight density,slightly above the film base,as it should be. Then I scanned the initial first exposure which should represent 18% density ie midtone. The camera should be set to expose at a midtone of approximately 18%,right? When I scanned it,using a Nikon 5000 ED,the histogram showed the three channels near the right edge (approx. 235 for each channel). I would have expected an average of128 or so (ignoring noise and grain) for each channel. My monitor is calibrated and profiled,gamma set at 2.2 etc. Am I missing something? As usual,thanks for all help. Ian Moore Link to post Share on other sites More sharing options...
Advertisement Posted April 12, 2014 Posted April 12, 2014 Hi ian moore, Take a look here R9 EXPOSURE CHECKING QUESTION. I'm sure you'll find what you were looking for!
pop Posted April 12, 2014 Share #2 Posted April 12, 2014 When I scanned it,using a Nikon 5000 ED,the histogram showed the three channels near the right edge (approx. 235 for each channel). At a guess, I would presume that the scanner was set to AE and that it was spreading the exposure and contrast as much as possible over the gamut. Link to post Share on other sites More sharing options...
