620max Posted March 13, 2014 Share #1 Posted March 13, 2014 Advertisement (gone after registration) Hello, which battery do you use on your M7? can I use 4X SR44 1.55v or LR44 1.5v for M7? Link to post Share on other sites More sharing options...
Advertisement Posted March 13, 2014 Posted March 13, 2014 Hi 620max, Take a look here SR44 battery for M7?. I'm sure you'll find what you were looking for!
andybarton Posted March 13, 2014 Share #2 Posted March 13, 2014 I have always used LR44s in my M7 and now my MP. Link to post Share on other sites More sharing options...
Guest Posted March 13, 2014 Share #3 Posted March 13, 2014 Hello, which battery do you use on your M7? can I use 4X SR44 1.55v or LR44 1.5v for M7? You can use 4x SR44 batteries, but apparently it's not recommended... something to do with circuits n' stuff. Stick to 2x LR44. Link to post Share on other sites More sharing options...
payasam Posted March 14, 2014 Share #4 Posted March 14, 2014 According to the manual, "the LEICA M7 requires two 3 volt DL 1/3N type lithium batteries." Perhaps you mean the M6, whose manual says that the "exposure meter can be powered by two 1.55-volt silver oxide button cells, or by one 3-volt lithium cell." The alkaline kind of cell is only nominally 1.5 volts. It does not put out a constant voltage over its life span. [edit] Sorry, I missed the "4X" in the first post, which then has to be about the M7. Link to post Share on other sites More sharing options...
620max Posted March 14, 2014 Author Share #5 Posted March 14, 2014 but DL 1/3n is hard to found, LR44 is more common, so can I use 4x LR44 for the M7, is any problems with that? thanks Link to post Share on other sites More sharing options...
payasam Posted March 14, 2014 Share #6 Posted March 14, 2014 Your exposure meter readings will not be accurate or consistent. The LR44's output voltage varies over the cell's life span. The SR44 is much to be preferred as it puts out a constant 1.55 volts. Link to post Share on other sites More sharing options...
stevesurf Posted March 14, 2014 Share #7 Posted March 14, 2014 Advertisement (gone after registration) BTW, DL 1/3N, what I use are plentiful and low cost: Qty (6) for $13.26!!! Duracell DL1/3NBPK Ultra Photo Lithium/Manganese Dioxide Battery, 1/3N Size, 3V (Case of 6): Amazon.com: Industrial & Scientific Link to post Share on other sites More sharing options...
payasam Posted March 14, 2014 Share #8 Posted March 14, 2014 620max, in Hong Kong you should have no trouble finding either lithium or silver oxide. Link to post Share on other sites More sharing options...
620max Posted March 15, 2014 Author Share #9 Posted March 15, 2014 620max, in Hong Kong you should have no trouble finding either lithium or silver oxide. Thanks but actually, these are difficult to find at local shop, maybe I need to try purchase from the web's order.... Link to post Share on other sites More sharing options...
payasam Posted March 16, 2014 Share #10 Posted March 16, 2014 Searching on the Net or on eBay, you turn up almost everything. No single physical shop stocks all things. I live in India, where it seems that SR44 cells and lithium batteries are simply not to be had: so I depend on eBay. Link to post Share on other sites More sharing options...
swamiji Posted March 24, 2014 Share #11 Posted March 24, 2014 I find where I live, it's either feast or famine. When available, I stock up, and always carry extra. Link to post Share on other sites More sharing options...
gabriel Posted March 24, 2014 Share #12 Posted March 24, 2014 The Small Battery Company in the UK stock SR44 Batteries at a reasonable price see: 357 SR44 silver oxide watch batteries. Battery equivalent to D303 D357 D303/357 GS13 228 357 280-62 J SB-B9 SR1154 SR44 SR44W SR44H 541 SP357 V357 4276 KS76 280-8 SR76E 1131SO They also stock alternatives. Link to post Share on other sites More sharing options...
Martin B Posted August 9, 2016 Share #13 Posted August 9, 2016 Revitalizing this old thread which I found when googling online - I have also an M7 now, and I wonder if I can use 4x 357 silver oxide batteries instead of the two large ones. I have also an M6 where the 357 batteries with 1.5V are being used (two of them). Link to post Share on other sites More sharing options...
Martin B Posted August 10, 2016 Share #14 Posted August 10, 2016 I found my question above answered in this thread below: http://lavidaleica.com/forum/viewtopic.php?t=360 It seems a feasible option to use 4 357 silver oxide 1.5 V batteries instead of two CR1/3N 3V batteries. Did anybody try this already? Link to post Share on other sites More sharing options...
Greeneggsnospam Posted October 25, 2016 Share #15 Posted October 25, 2016 The Renata SR44 works fine and lasts long. LR44s will work but the AE may not be that accurate (display shows low battery alert). Link to post Share on other sites More sharing options...
