evering Posted January 29, 2014 Share #1 Posted January 29, 2014 Advertisement (gone after registration) Hello, I have had a M6 for a few months now and not had a problem. Now the left meter arrow will not light up. The right arrow will dissapear when I move the exposure dial or the appature ring however the left one no longer lights up. Any ideas? thanks Link to post Share on other sites More sharing options...
Advertisement Posted January 29, 2014 Posted January 29, 2014 Hi evering, Take a look here M6 Meter Arrow not working. I'm sure you'll find what you were looking for!
CalArts 99 Posted January 29, 2014 Share #2 Posted January 29, 2014 This happened on my M6. It was a cold solder joint which according to Don Goldberg (DAG) is somewhat common (he said he sees around 5 a year with this issue.) If the LED diode itself is bad, then the circuit board will need replacing. He says that is very uncommon. The repair for the cold solder joint was a fast turnaround and not expensive. Have any good Leica tech check for you and hopefully it's just a solder joint issue. btw, it was the left side for me, too. Link to post Share on other sites More sharing options...
