35 mm summaron
My bayonet mount 35 mm f2.8 summaron has no red dot on it. Can anyone tell me if this lens (no 1665628) is one of the batch that can be screw mount or bayonet mount. I believe that some 2000 of such lenses were made. Many thanks
Post a couple of photos, it helps.
cheers.
The Red Dot may have fallen off, as they sometimes do. I had to replace a couple of mine over the years. Does your lens have a little circular indention where the dot should typically go? If so, yours probably fell off at some time in the past.
Check if there is a tiny screw on the outside circonference of the rear flange.
This s/n example gives the 35 frame in the M2 camera
