Leica apo 135mm 3.4 Framelines
Guest guy_mancuso
Here is the last version of the 135/2.8. With the goggles and a 1.33 magnifier it's like focusing a 50 (+ you get accurate framing). I can't imagine trying to focus a 135 without the additional magnification. Wonder why Leica ditched the goggles, they work very well. The 2.8 doesn't quite have the sparkling snap of the new 135 but it's a very nice portrait lens. I am thinking that the 65 elmar on the Viso can do double duty as a flattering old school portrait lens so the 135 may go. I am going to be doing some side by side tests to see.
Guest guy_mancuso
Hot Damn it's PERFECT. Oh baby my 180 look is back , yes folks i love this stuff . Nice and sharp and bam beautiful falloff. 135 apo at F8.
i stole the WATE adapter which has the Leica 49mm IR filter in it and just taped it to the front so i had a IR filter for this shoot. this is just a quickie from today
Guest guy_mancuso
See here is that falloff i like
Guest guy_mancuso
One more quickie
Guest guy_mancuso
It's a little tough to shoot with but this one is heavy overcast but i think it looks pretty good
Hi Guy,
You do make it look easy. Those are beautiful and I do see the subtle fall off that you are talking about. Good examples for that.
Bob
Well my 135mm apo just showed up and WOW this thing is very sharp lens even wide open , great choice for me. But what framelines should come up. i was hoping 28-90 would and i am getting 24-35 frames. Is this correct ??? Is there a way i can change it on a permenant basis to 28-90. i can use the lever which helps
Hi Guy,
It triggers the 35 because 24/35/135 all use the same bayonet pattern. Enjoy it.
Cheers,
Sean
Guest guy_mancuso
I sent a e-mail to our friends at leica this morning and asked about switching out the mount to the 28-90 frameline mount. There going to look into it and see if that can be done the see no real problem with the idea. At least the 90mm will give you a better approximation of the field of view. That was my hardest part was my framing because the focusing patch was hard to go by. I try to shoot not to crop at all or very little so this would help. The issue with the external finder is i can't use flash at the same time because i need the Hot shoe for the remote transmitter for strobes.
