Edwin Ho Posted December 11, 2013 Share #1 Posted December 11, 2013 Advertisement (gone after registration) Please refer page 91 of user manual. I plan to use a small Olympus S20 auto flash occasionally as it gives a little more flash power than the built in flash. For this I set the camera to M mode with a setting of ISO 400 f/5.6 and 1/250 sec. Then I register this as a custom setting in C1. This will be the standard setting that I will use whenever the Olympus flash is used. However there are times that I will need to tweak the aperture slightly for a brighter exposure; changing aperture setting from f/5.6 to f/4 (temporarily). The problem I have experienced is that this temporary change has become permanent in my custom setting C1 without even registering it again. I tested this by turning the camera off and back on again turning to C1 mode; it has now changed to f/4 instead of the original setting of f/5.6. The menu states: Even if the menu settings are changed temporarily with [ C1], [C2-1 ], [C2-2] or [C2-3] selected, what has been registered will remain unchanged. I am puzzled and appreciate if someone who has the answer could enlighten me, thanks. Link to post Share on other sites More sharing options...
Advertisement Posted December 11, 2013 Posted December 11, 2013 Hi Edwin Ho, Take a look here D Lux 5 Question - Using Custom Mode. I'm sure you'll find what you were looking for!
