Leather case for an M with Multifunctional Grip?
bephoto
Does anyone know who makes leather half cases for a Leica M hooked up to a Multifunctional Grip?
No, I also am very interested in this. Problem is the grip is only just becoming available and probably not yet available to case manufactures as a template.
The outer case of the MFG appears to be thin plastic which is easily marked. You can feel it flexing when squeezed. I wonder if the range of wifi cards is extended due to it being plastic?
Bob.
Bob.
I really care about the range of the GPS. That's why I want one.
The inside base of the MFG is metal so WiFi cards probably won't work, also they could interfere with GPS operation.
So far the GPS seems to acquire a lock outdoors in 10s to 40s and up to 2min indoors as long as you are a within one or two metres of a window.
One application will be to use it in wooded/forest areas. It will be a few weeks before I can try it under these conditions. As winter approaches the trees are shedding their leaves which will influence the results.
Bob
