Best finder for CV 15 on M8
prav66
Gary, funny you should mention that. I got one recently (the CV21 finder) and everything I shot was about 5 degrees off axis. Turned out that the glass element in the finder was installed improperly. Sent it back and got one with correctly adjusted framelines.
SP
I just discovered the problem this weekend. Must've been the first time I used this finder on shots including the horizon. Guess I'll have to see about getting it exchanged.
discovered the same problem with mine. i had it for about 3 weeks. do you think i should be going back to b&h or the manufactorer?
thanks
m
I'd send it back to the place where you bought it with a polite note asking for an exchange. Certainly, in UK, it is the person who sold it to you who is responsible for it being 'of merchantable quality' and for replacing it if it isn't.
It might also be worth asking the shop to inspect the replacement before they send it to you, to make sure that it's OK.
thanks, you are right. but in the states they often suggest going to the manufactorer. in any case, i live close to b&h and they took it back without any problems. unfortunately, they were also out of stock. might consider getting a used leica or other third-party 21mm viewfinder...
cheers
m
