Hard case for M8?
Photoskeptic
Does Leica or anyone else make a hard case for the M8? I'm not referring to Luigi's. I want one just for traveling to keep the camera from harm. I once busted the LCD on a DSLR I carried rather loosely in a carry-on. I don't care for camera bags as they are too conspicuous. I've been using an Optech soft case, but don't feel it is optimal.
Thanks for all replies.
x
Pelican in California makes a nice range of very secure cases (http://www.pelican.com).
I bought a model 1200 from B&H for $33.25 and adapted it to accomodate the M8 plus the charger, a 35-mm lens, and a 75-mm lens, either one mounted or not. It is about the size of two bricks (or a small shoe box) and has a nice robust handle. If you have more kit, you will require a larger size, but there is a wide range available, right up to wheelied ones.
The case come with a foam insert that is customizable to the contents by removing pre-cut 1/2-inch units of foam. Unfortunately, I do not regard the foam as sufficiently durable to leave it "as is," so I have lined the foam with sticky-backed felt fabric.
When it closes, it is sealed inside with a 360-degree rubber o-ring. The manufacturer says it will float in salt water, although I don't get the same personal assurances. With the right kind of padlock, it can be locked.
Philip Kozloff
