Guest Walt Posted April 7, 2007 Share #1 Â Posted April 7, 2007 Advertisement (gone after registration) I don't recall this being discussed, but I have now seen a phenomenon on three samples of the M8 (all FW 1.092) that should be added to Leica's "laundry list." Sometimes, when a slow shutter speed triggers the noise reduction routine, instead of producing an image two or three (I think two) completely white frames are produced. Because I do not shoot at these very slow shutter speeds that often (around 1 second) I have not seen this often, but I have seen it on all three cameras. It does not always occur with NR, but often enough that it is disturbing and will result in a significant number of lost exposures when the NR routing is invoked. Â Thanks, Walt Link to post Share on other sites More sharing options...
Advertisement Posted April 7, 2007 Posted April 7, 2007 Hi Guest Walt, Take a look here NR produces white frames . . .. I'm sure you'll find what you were looking for!
