salmon78 Posted April 5, 2007 Share #1 Â Posted April 5, 2007 Advertisement (gone after registration) On the gretag color checker, which box should be used for setting the WB with the eye-dropper tool? Link to post Share on other sites More sharing options...
Advertisement Posted April 5, 2007 Posted April 5, 2007 Hi salmon78, Take a look here Setting WB with GT CC. I'm sure you'll find what you were looking for!
Guest guy_mancuso Posted April 5, 2007 Share #2 Â Posted April 5, 2007 Bottom second from the left or the the 3rd would work also Link to post Share on other sites More sharing options...
35mmSummicron Posted April 5, 2007 Share #3 Â Posted April 5, 2007 to get a "neutral grey" you typically want to click on an area between 120-180 this obviously depends on the lighting, and is usually the 3rd gray patch on the larger GMB chart. Â an abosolute neutral gray reading in photoshop is 128, 128, 128 Â as long as you zero the RGB chanels so they are the same you will get a neutral light source, the reason you want to get within these values is so you don't clip anything (easy to do in the highlight/shadow areas, which is why it isnt always good to WB off a whitecard). Â hope this helps. Â andy Link to post Share on other sites More sharing options...
salmon78 Posted April 6, 2007 Author Share #4 Â Posted April 6, 2007 Thanks guys. Veyr helpful. Link to post Share on other sites More sharing options...
