miatadan Posted June 12, 2013 Share #1 Posted June 12, 2013 Advertisement (gone after registration) Since the Leica X Vario is using 18-46mm field of view 28-70mm on 1.5x sensor 28mm setting: F/3.5 35mm setting: F/4.5 50mm setting: F/5.1 70mm setting: F/6.4 F/6.4 70mm narrow end slow compared to most other zooms Canon EF-S 18-55mm f/3.5 - f/5.6 IS Nikon AF-S 18-55mm f/3.5 - f/5.6G VR Sony SAL1855 DT 18-55mm f/3.5 -f/5.6 Pentax smc DA -18-55mm f/3.5 -f/5.6 the exception and on paper best spec zoom lens is the Fuji XF 18-55 f/2.8 - 4 OIS So to me is the question how much slower is f/6.4 compared to f/5.6 in actual use? What is build quality of lens that Leica is using in X Vario ? how good is glass used, how good is coating? mostly metal construction or cheap plastic like most cheap kit zooms? The Fuji XF 18-55 f/2.8 - 4 OIS happens to be fastest zoom as well as best build quality so far ( almost all metal... According to reviews ( Reid Reviews and Jono Slacks ), reason for slower glass is better optical performance. So maybe we are being to critical and not going this new model a chance. For me I am happy that the lens does not retract into body like the X2 and not needing Kiwi tube to reduce chance of dust on sensor. One question though is it possible to put lens filter ( protector ) on X Vario Dan Link to post Share on other sites More sharing options...
Advertisement Posted June 12, 2013 Posted June 12, 2013 Hi miatadan, Take a look here Zoom lens on X Vario. I'm sure you'll find what you were looking for!
Gabriel66 Posted June 13, 2013 Share #2 Posted June 13, 2013 It is 0.5 stops faster closed. It is not a huge amount, but certainly "sounds" worse! Gabriele http://www.caproni.it Link to post Share on other sites More sharing options...
dkCambridgeshire Posted June 13, 2013 Share #3 Posted June 13, 2013 For me I am happy that the lens does not retract into body like the X2 and not needing Kiwi tube to reduce chance of dust on sensor. One question though is it possible to put lens filter ( protector ) on X Vario Dan The lens has a 43mm filter thread ... but it is not mentioned in the specifications. dunk Link to post Share on other sites More sharing options...
jonoslack Posted June 14, 2013 Share #4 Posted June 14, 2013 I think that: f2.8 - f3.5 = 1/2 stop f5.6 - f6.5 = 1/3 stop . . . although of course, f4 - f5.6 = 1.1/3 stop - which is fairly significant. It is sad though - if the lens was f2.8 to f5.6 nobody would give it a second thought. Link to post Share on other sites More sharing options...
Ruhayat Posted June 16, 2013 Share #5 Posted June 16, 2013 ...It is sad though - if the lens was f2.8 to f5.6 nobody would give it a second thought. ...Or they'd just bitch about how big the damned thing is instead. Link to post Share on other sites More sharing options...
