Matmcr Posted October 20, 2012 Share #1 Posted October 20, 2012 Advertisement (gone after registration) Hi all, Ok, I've just bought a Plustek Opticfilm 7400 and already use an Epson v700. The 7400 came with Silverfast 8 and I already have VueScan and I wondered if anyone had any advice on gaining the best scan quality from the various settings in the software and what to avoid? Which do you find the most suitable for your needs? I've read that a lot of people use the v700 to get a contact sheet and then scan individual frames with the Plustek. The thing is I'm not seeing much difference between the two scanners, and I have also read that the Plustek is supposed to be better quality for 35mm? I know it's not a Nikon Coolscan, but I have also read that some people are getting near that level of quality with the Plustek. Any help of advice would be greatly appreciated! Mat Link to post Share on other sites More sharing options...
Advertisement Posted October 20, 2012 Posted October 20, 2012 Hi Matmcr, Take a look here Plustek Opticfilm 7400 scanning advice!!. I'm sure you'll find what you were looking for!
tobey bilek Posted October 21, 2012 Share #2 Posted October 21, 2012 I uninstalled all Silverfast software. Too many icons, not enough words. But if you have to use it, all scanners work better on manual. Set up a WB, exposure, contrast, and run it. Well exposed film will need little or no tweeking. Save a preset for each type of film. Auto is like a automatic transmission, works decently most of the time except when you really need it to work, then it retards spark, shifts slowly etc. Not to say you can not beef up an auto to work better and it is done all the time. But then you run into warrantee issues, fuel economy and emission standards. If it a race car, you need not worry about such things. Link to post Share on other sites More sharing options...
Matmcr Posted October 22, 2012 Author Share #3 Posted October 22, 2012 Thanks Tobey, good advice. Anyone anything else to add? cheers. Link to post Share on other sites More sharing options...
kokoshawnuff Posted October 22, 2012 Share #4 Posted October 22, 2012 I like you have a V700 (for web and small prints) and also a 7400 for larger prints. I use it with Vuescan and have presets for the types of film I use. All the presets where determined by dozens of minute changes among all the settings...takes a while but you'll only need to do it once. Also the actual resolution is only about 3800ppi, not the 7200 that's claimed. For some negatives multiexposure feature can be quite useful and I always use the multisample feature (typically 6 passes). Here's a pretty thorough review: Film scanner-test Plustek OpticFilm 7400: Scanning slides and 35mm-film strips with film adapters but without the dust and scratch correction based on the hardware Link to post Share on other sites More sharing options...
Matmcr Posted October 23, 2012 Author Share #5 Posted October 23, 2012 Thanks for the info. I'll try the multisample feature. I like you have a V700 (for web and small prints) and also a 7400 for larger prints. I use it with Vuescan and have presets for the types of film I use. All the presets where determined by dozens of minute changes among all the settings...takes a while but you'll only need to do it once. Also the actual resolution is only about 3800ppi, not the 7200 that's claimed. For some negatives multiexposure feature can be quite useful and I always use the multisample feature (typically 6 passes). Here's a pretty thorough review: Film scanner-test Plustek OpticFilm 7400: Scanning slides and 35mm-film strips with film adapters but without the dust and scratch correction based on the hardware Link to post Share on other sites More sharing options...
Matmcr Posted October 23, 2012 Author Share #6 Posted October 23, 2012 Oh and thanks for the review—I'll give that a good read. v much appreciated. Link to post Share on other sites More sharing options...
