woorob Posted October 13, 2012 Share #1 Â Posted October 13, 2012 Advertisement (gone after registration) Hi, I'm new to this forum but not to Leica, having used Leicas for mnay years. Â I have a Zeiss 18mm f/4.0 ZM that I use with my M9-P. I had Don Goldberg add 6-bit coding to the lens but the camera will not automatically recognise the lens. I've had him add 6-bit coding to three other lenses (all Leica) and the camera recognises them every time. Â The lens code I'm using for this lens is 110100, which I understand is the correct code for the Leica Super-Elmar-M 18mm f/3.8 ASPH. I repainted the slots to make sure there was enough paint, using Testors flat enamel in black and white. When this didn't work I used a black Sharpie on the black slots, and that didn't work either. Â I'm wondering if anyone else has been able to code this lens successfuly for use on an M9? Perhaps I should try coding it as a pre-ASPH 21mm (code 000001)? Â Any help would be greatly appreciated! Â Thanks, Â Bob Woods Link to post Share on other sites More sharing options...
Advertisement Posted October 13, 2012 Posted October 13, 2012 Hi woorob, Take a look here 6-bit coding for the Zeiss 18mm f/4.0. I'm sure you'll find what you were looking for!
peterbengtson Posted October 13, 2012 Share #2 Â Posted October 13, 2012 Make sure the flange brings up the same frame lines as the Leica 18mm. Lens coding really is 8 bit when you consider the frame line information as 2 more bits (3 options) Link to post Share on other sites More sharing options...
woorob Posted October 13, 2012 Author Share #3 Â Posted October 13, 2012 Very helpful, thanks. I think this is my problem, and have sent an e-mail to John Milich inquiring about a new or modified flange for the lens. Â Thanks again! Link to post Share on other sites More sharing options...
Ivar B Posted October 23, 2012 Share #4 Â Posted October 23, 2012 I am not sure if the mount can be modified or not - you may need a new one bringing up the 28/90 frame lines. I had the lens once and bought a new mount from Zeiss. As I recall, it was inexpensive at 25 Euros or something. You may also need to order a set of screws as these can become damaged when the mount is taken off. Â The 4/18 is a stellar performer. Link to post Share on other sites More sharing options...
