Flash Woes....
albertknappmd
I just got my Metz 54MZ-4i digital to use with my DMRs. i started palying around withy it last night and am used to teh Metz system as I ahd a 40MZ for years. Anyway, I noticed that the SCA3502 Mk5 works perfectly as the ISO,aperture, focal length and flash symbols were communicated without problem from camera to flash and vice versa....
But, I noticed two problems that I could not sort out.
#1 In Aperture priority and with the flash in Auto mode (as ttl is a no-no in digital), the camera's speed did not automatically go to 1/250. In fact the speed remained at the correct ambient light level. For example, I was shooting a still life at f/2 with the speed of 1/8. I turned on the flash to A and the elelctric bolt appeared in the viewfinder as expected but the speed remained 1/8. When I exposed teh picture, the flash went off bu the camera shuuter remained open for the entire 1/8 second. I repeated this multiple times. i then did it in 2nd curtain and again the camera exposed for 1/8 sec before triggering the flash at the end of the exposure. IT SEEMS THAT THE CAMERA AND FLASH ARE NOT SYNCHRONIZING IN AUTO MODE. This is perplexing for as I said previously all other SCA3502 functions seem to work. The Metz instruction manual is its usual useless self.
#2 Again in Auto mode, I experimented with flash suprression by changing the EV to -1 2/3 for fill flash. Took pictures at EV=0 and EV=-1 2/3 and exactly the same !!! Where is the flash suppression.
Any ideas ??? :mad::rolleyes::confused:
The Metz instruction booklet states that when the flash is in auto mode and the camera is in Aperture priority, then the speed is automatically set at 1/250. You can change this on your own if you want but it should defer to 1/250.... There must be a simple answer to this as the same behavior was noted on BOTH of my DMRs... :confused:
I use the Leica 24D and like it. I use primarily for fill flash. It automatically syncs with the camera.
The exif on the last few flash shots showed 1/250th of a second exposure time, and I had the camera speed set to auto.
