24D Flash and Pocket Wizards
Paul J
almost every flash with central pin will work with the pocketwizzards ....... in manual mode, of course. The best solution is to keep one setting for manual mode and one for TTL (Nikon only)
Theoretically the Nikon could work as the pins are identical to the Leica. The SC-17 cable does work, but in practice it does not.
I use the PocketWizard Plus III with a hot shoe adapter, in Manuel mode.
PW has no product that provides TTL for Leica!
Thanks, I use Plus II's, they work well (except for the size). But I do wonder if the TTL Nikon Wizards work since the Nikon TTL cord does. The Mini TTL is..well...mini!
I wish they did, I would use them as well.
