hand-coding idea
footnoteblog
Has anyone brought up or considered manufacturing stickers for lenses (and an appropriate, easy-to-use applicator and instructions?)
Shipping would be so low, I could see offering a sheet with die-cuts of each possible, existing focal length for say, $15 a piece.
I have design chops (professionally trained in both practices), if anyone wants to talk about this.
Jack, there may not be enough clearance in the mount for a sticker. And, continous grinding of a paper sticker in such a narrow space might release paper particles into the body.
Leica has patents on the coding, so any application by a 3rd party would be a violation. I think only do-it-yourself for the lens coding will be possible. This is the reason Rangefinder forum abandoned the idea of offering an independent coding service.
It's smart of them to do the patent thing.
Now, to echo Sean and others, since Leica is the inventor of the open system, how 'bout they put an option in the menu to identify the lens. It works against the revenue model whereby people send their Leica lenses in for coding, but definitely makes sense.
That's pretty messed up to not allow a menu selection for a tiny revenue generator.
That's what I call bad business. If this was really a source of revenue, then they've got their business plan all screwed up. If not, then great; get to work on the menu selection!
I think the source of revenue is the sale of new Leica lenses. Some people are just selling their old lenses and buying coded ones.
This could be done with mylar stickers (not paper) and could possibly last at least a reasonable number of lens changes. Not something a pro would want, but for those with, say, a non-Leica wide-angle used most of the time, it could be very handy. Of course, Leica could have given us a manual lens-ID option in the software, couldn't they?
There is no law against printing B&silver stickers - I don't think the bar code itself could be copyright in any civilised countries. Where you stick it is up to you.
So - can you print on Mylar?
Well, technically, I suppose, there isn't ANY room in there. And anything in the way is going to slightly shift the lens mounting. But there is certainly some tolerance. With a new camera and lens, though, I doubt a sticker would last very long.
It might work using an M-screw adapter (anyone know of anyone making screwmount wideangles???). You could just leave an adapter on the body. In fact, I've heard there is actually an entire range of screwmount lenses. Can that be true? :-)
A Mylar sticker might also work with a "cutaway" adapter.
There is simply not enought tolerance there for anything. If there is, your mount is loose. That is why Leica recesses the code.
Manual entry - including user specific abbreviations - could work and makes a lot of sense.
But you should know that my unmodified M8 with 1.092 recognizes my uncoded 90mm Tele Elmarit. How it does this is somewhat of a mystery; I think it is the selection lever. At first I thought it was the default coding of all blank - but that is not the code. Any others who found the same?
