Stan Raucher Posted March 6, 2007 Share #1 Â Posted March 6, 2007 Advertisement (gone after registration) Has anyone successfully hand coded a VC21 or VC15 lens mounted on a 28/90 Voigtlander screw mount adapter, or does the cut-out area on the adapter preclude hand coding? Â Thanks, Â Stan Link to post Share on other sites More sharing options...
Advertisement Posted March 6, 2007 Posted March 6, 2007 Hi Stan Raucher, Take a look here Hand Coding VC21 or VC15 with Voigtlander screw mount adapter. I'm sure you'll find what you were looking for!
steve_l Posted March 6, 2007 Share #2 Â Posted March 6, 2007 And, does any other VC adapter code more easily? (35/135, 50/75) - it doesn't really matter which frame lines come up! Link to post Share on other sites More sharing options...
george + Posted March 6, 2007 Share #3 Â Posted March 6, 2007 Stan, I think the cutout precludes coding. You can see parts of the sensors under the lens. Â But if anyone was successful, please let us know. Link to post Share on other sites More sharing options...
finkaudio Posted March 6, 2007 Share #4  Posted March 6, 2007 Stan, I think the cutout precludes coding. You can see parts of the sensors under the lens.  But if anyone was successful, please let us know.  I have done it on the 15 and the 21mm   Works OK on both.  Best regards  Karl-Heinz Link to post Share on other sites More sharing options...
Stan Raucher Posted March 6, 2007 Author Share #5 Â Posted March 6, 2007 Thanks Karl-Heinz. Is that just a piece of paper between the lens and the mount? What framelines do you have to activate for the correct focal length to be recorded in the EXIF data? Â Stan Link to post Share on other sites More sharing options...
finkaudio Posted March 7, 2007 Share #6  Posted March 7, 2007 Thanks Karl-Heinz. Is that just a piece of paper between the lens and the mount? What framelines do you have to activate for the correct focal length to be recorded in the EXIF data? Stan   Hi Stan,  yes, it's just a pice of paper  I used the 28-90 adapter and coded both lenses as 21mm - no Leica 15mm so far. That was all I had to do.  Best regards  KH Link to post Share on other sites More sharing options...
mr_big Posted March 7, 2007 Share #7 Â Posted March 7, 2007 Advertisement (gone after registration) I believe you can use a Leica 9cm screwmount adapter which doesn't have the cutout. You might be able to find one on ebay. I found mine at a camera swap meet. Link to post Share on other sites More sharing options...
