Jeff S Posted May 10, 2012 Share #1 Posted May 10, 2012 Advertisement (gone after registration) ...with new lenses according to this Rumors post. Edit...meant to also include this link. Jeff Link to post Share on other sites More sharing options...
Advertisement Posted May 10, 2012 Posted May 10, 2012 Hi Jeff S, Take a look here S System Expanded . I'm sure you'll find what you were looking for!
stephan_w Posted May 11, 2012 Share #2 Posted May 11, 2012 they are allready announced for more than 2 years! will they ever come`? Link to post Share on other sites More sharing options...
rosuna Posted May 11, 2012 Share #3 Posted May 11, 2012 Leica's S to Hasselblad H adapter: Leica dramatically expands S system with Hasselblad lens adapter - British Journal of Photography Assuming the possibility of a S3 based on a CMOS sensor... Is the "R solution" a similar adapter R to S? Link to post Share on other sites More sharing options...
stephan_w Posted May 14, 2012 Share #4 Posted May 14, 2012 Assuming the possibility of a S3 based on a CMOS sensor... Is the "R solution" a similar adapter R to S? not possible due to an incompatible layout of the cameras Link to post Share on other sites More sharing options...
rosuna Posted May 16, 2012 Share #5 Posted May 16, 2012 not possible due to an incompatible layout of the cameras The lens to flange distance? Yes, that is the main problem, but the diameter of the S mount might allow an adapter... (I don't know this for sure, of course). CMOS sensors may "cut" the sensitive area, like the Nikons do, so 24x36 active areas are possible inside the 30x45 format. Link to post Share on other sites More sharing options...
stephan_w Posted May 16, 2012 Share #6 Posted May 16, 2012 The lens to flange distance? Yes, that is the main problem exactly, so this solution isn't one. The only R-Lenses that can be adapted are the longer lenses from Leica, as the Modul-System and (if I'm well informed), the 280 Apo-Telyt Link to post Share on other sites More sharing options...
rosuna Posted May 27, 2012 Share #7 Posted May 27, 2012 Advertisement (gone after registration) The S-Magazine for iPad second issue (free) has a wonderful article about the new central shutters... They have been fully developed by Leica and are unique in the industry... Link to post Share on other sites More sharing options...
rick_dykstra Posted August 19, 2012 Share #8 Posted August 19, 2012 exactly, so this solution isn't one. The only R-Lenses that can be adapted are the longer lenses from Leica, as the Modul-System and (if I'm well informed), the 280 Apo-Telyt Does anyone have any more information on this? Fitting the APO-Telyt R Modul lenses to the S2? Could it be that their ability to focus way beyond infinity is part of the solution? The 280/4 and 180/2 could be in the same boat. Interesting. Thanks. Rick. p.s. found this http://www.apotelyt.com/photo-lens/leica-apo-telyt-r-module which says; "Since Leica discontinued its R-line of SLR-cameras, the lens system is now somewhat orphaned. However, adapters for Leica R-lenses to other camera brands can be easily found on ebay, so that the APO-Telyts can have a digital future beyond the 10MB backs available for the R-cameras. Moreover, Leica expert David Farkas and colleagues have successfully modified the lens barrel and mount on one copy, such that the APO-Telyt can be used on the medium format Leica S2 (and yes, the image circle of the tele-lenses is apparently large enough to cover the full S2-sensor without significant vignetting)" Link to post Share on other sites More sharing options...
georg Posted August 25, 2012 Share #9 Posted August 25, 2012 In fact there is someone who adapts the R-tele-lenses to the S2 with apparantly excellent results. Norbert Rosing (one of the very best wildlife-photographers worlwide) seems to use the combination S2+Modul-System currently. See this thread: http://www.l-camera-forum.com/leica-forum/s2-forum/240681-s2-r-teleobjektive.html And the link: Leibfritz Konstruktion or info@lei-ko.de Link to post Share on other sites More sharing options...
