Andykcole Posted May 1, 2012 Share #1 Posted May 1, 2012 Advertisement (gone after registration) Hi All Has anyone had this problem.. both my S2s with Grips show the following... email sent to Solms awaiting reply as follows.. I have noticed that with the Battery Grip attached the top Cover OLED brightness is now defaulting to ‘medium’ even after setting this to ‘high’ which is most annoying in bright daylight. the only way for me is to set it to ‘high’ when first switching on and just letting the S2 go to standby....if I switch it off then it defaults to ‘medium’ again. please note there is no problem without the Grips can you help please ?? is there a solution via Wi-Fi firmware ??? I am using the latest 1020 firmware and have reinstalled it twice now with no resolution Link to post Share on other sites More sharing options...
Advertisement Posted May 1, 2012 Posted May 1, 2012 Hi Andykcole, Take a look here top OLED problems with Grip attached . I'm sure you'll find what you were looking for!
Andykcole Posted May 3, 2012 Author Share #2 Posted May 3, 2012 just had this reply from Germany Dear Mr Cole, Thank you very much for your message. Please be informed that our technical department was able to reproduce the issue as you described. It seems that this it is really an unreported bug. We thank you very much for your reporting. Leica's dedicated technical team will identify the issue's root cause and will fix this in one of the next firmware updates. end !! not many of you use the Grip then ??? Link to post Share on other sites More sharing options...
