off camera flash and m8 with wide lenses
afineman
so, am i just being paranoid about paralax issues? that looks like it is over 1 inch tall, do you have paralax problems?
I just did some shots with it and the 15mm. The framing seems as accurate as any other lens on the rangefinders. this was using the 21mm finder and no closer than about four feet. Infinity seemed fine too, just getting a touch more in the frame than the 21mm finder showed.
I also tried the GNC flash mode using the extension cord and it worked fine.
nikon won't work unless modified, i need to have a viewfinder for 21 / 28 on top of camera too. flash must sync with camera.
The Nikon cable will allow off-camera TTL control of the SF-24D with the M8 (according to the long write-up in LFI 02/2007 pg 35) so I assume you need the modification to allow the WA VF to be held in place?
