DLux-5 and Raynox DCR-250 macro lense
rachel@krusic.com
Hi all,
I just bought and love my new Leica DLux-5!
It has very good macro performance but I wanted a little more so I bought the Raynox DCR-250 based on user reviews and Alexander Whites book about using the DLux 5.
I am having some issues on focus and was wondering if any one has tips/tricks on how to use an add on macro lens.
I'm new to photography and am learning as I go along.
What I did do was;
1 - Put the camera in manual focus mode.
2 - Put the camera in A mode and maxed out my F number to 8.
3 - Maxed out my zoom, basically tele photo mode.
Images still look blurry.
I hope this added info doesn't confuse the issue so maybe its best to disregard :rolleyes:
Thanks in advance,
Rachel
Rachel, welcome to the forum and Leica photography!
While I have a D-Lux 5 I have no experience of using attachments with it. In the absence of any instructions, leaflets or via the internet, I would set the camera on a tripod with a controllable test subject. Zoom and frame the subject. In aperture priority mode set F/8. In manual focus mode try and focus on the subject.. The attachment will give you a limited range of sharp focus. Experiment by moving the test object nearer or further from the lens until you can get a sharply focused image. Shoot and assess the result. Modify the procedure until you achieve perfect focus. Live view is a considerable advantage in these close up situations.
Depth of field is very shallow at close ranges.
As you are very new to photography, may I suggest you spend more time mastering the camera and the basics before getting disillusioned wrestling with a quite demanding technique. It is a super little camera, capable of giving you very good results.
